KAWASAKI Ki-45 Toryu (NICK)
Jose Gerardo Casillas E
MensajePublicado: Mar May 15, 2007 6:33 pm    Asunto: KAWASAKI Ki-45 Toryu (NICK) Responder citando
Estimados colegas solicito su ayuda, ojala alguno de uds. me pueda dar algunos tips donde encontrar en internet informacion y/o walkaround del KAWASAKI Ki-45 Toryu (NICK).
SALUDOS
jerry wall
MensajePublicado: Mar May 15, 2007 7:57 pm    Asunto: Responder citando
Hola Gerardo:
Te mando estas web´s
Saludos Cool
http://todo-aviones.com.ar/japones/toryu/gal_toryu.html
http://wp.scn.ru/en/ww2/f/1159/65/1
Kawasaki Ki-45 Toryu ("Nick")
Type Twin-engine heavy fighter
Manufacturer Kawasaki
Maiden flight May, 1941
Introduced October, 1941
Retired 1945
Primary user Imperial Japanese Army
Number built 1,370
The Kawasaki Ki-45 Toryu (屠龍, "Dragon Slayer") was a two-seat, twin-engined fighter used by the Imperial Japanese Army in World War II. The army gave it the designation "Type 2 two-seat fighter"; the Allied codename was Nick.
Background
In response to the rapid emergence in Europe of twin-engine heavy fighters such as the Messerschmitt Bf 110, the army ordered development of a twin-engine, two-seat fighter in 1937, and assigned the proposal by Kawasaki Shipbuilding the designation of Ki-38. This only went as far as a mock up, but by December of that year, the army ordered a working prototype as the Ki-45, which first flew in January 1939. Results from the test flights, however, did not meet the army's expectations. The Ha-20 Otsu engine was underpowered and failure-prone, while the airframe suffered from nacelle stall.
The Ki-45 did not enter use, but the army, insistent on having a working twin-engine fighter, ordered Kawasaki to continue development. Kawasaki responded by replacing the engines with the proven Nakajima Ha-25. Flight tests were promising.
In October 1940, the army ordered continued improvements such as switching to 805 kW (1,080 hp) Mitsubishi Ha-102 engines, and using the wings from the Ki-48 light bomber. This craft, designated Ki-45 Kai, was complete in September 1941 and was officially adopted for use by the army in February 1942 as the "Type 2 two-seat fighter".
Combat history
The Ki-45 was initially used as a long-range bomber escort. The 84th Independent Flight Wing used them in June 1942 in attacks on Guilin, where they encountered, but were no match for, P-40 Tomahawks flown by the Flying Tigers. In September of the same year, they met P-40s over Hanoi with similar results. It became clear that the Ki-45 could not hold its own against single-engine fighters in aerial combat.
It was subsequently deployed in several theaters in the roles of interception, ground and ship attack, and fleet defense. Its greatest strength turned out to be as an anti-bomber interceptor. In New Guinea, the JAAF used the aircraft in an anti-ship role, as the Ki-45 was heavily armed with one 37mm and two 20mm cannons and could carry two 250 kg (550 lb) bombs on hard points under the wings. 1,675 Ki-45s of all versions were produced during the war.
The first production type (Ko) was armed with two 12.7 mm cannon in the nose, a single 20 mm in the belly, and a movable 7.92 in the rear cabin, and this was followed with the Otsu with the lower 20 mm cannon replaced by a 37 mm tank gun, to counter B-17 bombers. While the firepower was devastating, manual reloading meant that only two rounds could be fired per minute. The next type (Hei) restored the 20 mm cannon, and this time placed an automatic 37 mm gun in the nose. A later addition was twin obliquely-firing 20 mm cannon behind the cockpit and removal of the underside 20 mm guns.
Soon after entering service, the Ki-45 was assigned to home defense, and several were dispatched against the Doolittle raid, though they did not see action. The craft's heavy armament proved to be effective against the B-29 raids which started in June 1944. However, its performance was insufficient to counter B-29s flying at 10,000 meters. Modifications such as reduction of fuel and ordnance were attempted to raise performance to little avail, and in the end aircraft were used in ramming attacks. In 1945, the forward and upward-firing guns showed some results against with the commencement of night time bombing raids, but the lack of radar was a considerable handicap. By the spring of 1945, the advent of American carrier-based fighters and Iwo Jima-based P-51s escorting B-29s over the skies of Japan brought the Ki-45's career to an end.
The next version, Kawasaki Ki-45 KAIc were developed specifically for night fighting which were supposed to be equipped with centimetrical radar in the nose, but due to production difficulties this did not occur. Having the unique Japanese Army aircraft take part in night defense of the Home Islands equipped four sentais from the autumn of 1944 to the War's end. They obtained notable successes, and one sentai obtained 150 victories and downed 8 USAAF B-29 Superfortresses in their first combat.
Versions
Ki-45 (prototypes)
KI-45 Type 1 (modified operative models)
Ki-45 KAI Prototypes
Ki-45 KAI Preseries
Ki-45 KAIa Toryu two place fighter Type 2 of Army (Mark a) initial model of series
Ki-45 KAIb (mark b) version against land or naval objectives; engines, Mitsubishi Ha-102 of 1,050 hp (780 kW).
Ki-45 KAIc (mark c) -model b modified, night fighter version, equipped with one cannon Ho-203 of 37 mm in ventral tunnel, two fixed Ho-5 20mm cannons in dorsal frontal position, and one machine gun type 89 of 7.92 mm in back position.
Ki-45 KAId (Mark d) version against Naval objectives, two cannons of 20 mm and one of 37 mm in ventral position, one machine gun of 7.92 mm in back position.
Ki-45 II (only project)- completed how Ki-96 experimental prototype.
Total production: 1,701 units.
Specifications (Ki-45 Kai)
General characteristics
Crew: Two
Length: 11.00 m (36 ft 1 in)
Wingspan: 15.02 m (49 ft 4 in)
Height: 3.70 m (12 ft 2 in)
Wing area: 32.0 m² (344 ft²)
Empty weight: 4,000 kg (8,820 lb)
Loaded weight: 5,500 kg (12,125 lb)
Max takeoff weight: kg (lb)
Powerplant: 2× Mitsubishi Ha-102 14-cylinder radial engines, 727 kW (975 hp) each
Performance
Maximum speed: 540 km/h (336 mph)
Range: 2,000 km (1,243 mi)
Service ceiling: 10,000 m (32,800 ft)
Rate of climb: 11.7 m/s (2,300 ft/min)
Wing loading: 171.9 kg/m² (35 lb/ft²)
Power/mass: 0.26 kW/kg (0.16 hp/lb)
Armament
Ko: 1x 20 mm, 2x 12.7 mm, 2x 7.92 mm
Hei: 1x 37 mm, 1x 20 mm, 1x 7.92 mm
Cho: 1x 37 mm, 2x 20 mm
El cuerpo humano es el carruaje;
Platón
Francisco Martínez
MensajePublicado: Mar May 15, 2007 9:25 pm    Asunto: Responder citando
Estimado Gerardo
Tengo un libro en formato PDF que te puede ser útil, mañana tenemos junta, llévate tu laptop y te lo paso.
MensajePublicado: Mie May 16, 2007 2:39 pm    Asunto: KI 45 Responder citando
Mil gracias Jerry por tu ayuda seguimos en contacto en verdad te lo agradezco.
Francisco te veo hoy en la junta del club para que me pases ese archivo.
Cerón
MensajePublicado: Mie May 16, 2007 4:49 pm    Asunto: Perdón Responder citando
Mi buen Francisco Martínez, disculpa el atrevimiento pero, ¿no podrías hacerme el favor de enviarme también el archivo PDF que mencionaste??????? también me interesa... Laughing
Atte: Cerón
Pancho Villa
